Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Seagate firecuda 1TB SATA 6 Gb/s, 128 MB Cache (ST1000LX015)
I want to upgrade my computers hard drive and I want to buy the Seagate firecuda 1TB SATA 6 Gb/s, 128 MB Cache (ST1000LX015), however, I am not sure it is compatible with my Macbook Pro 13" Early 2011- i7 processor.
Is it compatible, and if not, what option should i consider??
Score 1
Add a comment
1 Answer
Chosen Solution
I've done this upgrade many times. I do change out the hard drive/IR cable to the 2012 model.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
UPDATE
I also use tape on either side of the cable as it comes over the optical drive to prevent contact damage from the bottom of the case. But I'm a professional, and do it so it won't fail again.
https://www.google.com/shopping/product/...
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Image
Product
$34.99
Score 3
4 Comments:
Thanks! But is the cable replacement necessary? or more of a precaution?
by
In addition of replacing the cable I would place some electrical tape on the uppercase where the cable rests to help protect it from abrasion.
If I replace a drive I replace the cable to make sure it's going to work reliably. Don't be penny-wise pound-foolish. A bad cable can mess-up your drive.
by
@danj Dan is absolutely correct. He's a consummate professional also and we do it right the first time.
by
Ok, thank you so much for the advice!!
by
Add a comment
Add your answer
Andrei Fuentes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 235
