Small chip/crack inside screen?
I have a small chip or splatter of something inside my screen. My laptop isn't that old (1 month) and never used it forcefully.
Link to the images: https://imgur.com/a/5u6hs
tylerkimble05 sure looks like a crack. I'dstart by contacting the seller and see if you can get it covered under warranty. After that you should also contact Samsung and see if they can help you with that. If nobody can/does, then you need to consider replacing the display or may be learn to live with it and leave it as is.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,162
I have a crack in my note 7 spin screen that looks exactly the same but a little bigger! Are you still able to use the touch screen since you’ve noticed this?
by Gabi Hagelstein
