Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
Do I need A New Graphics Card?
I have an Acer Aspire r5-471T. I think my graphics card may have messed up. My screen won't turn on but the led indicators do. I tried the battery reset and that did not help. I know my model has integrated graphics (intel 520) but I don't know how to fix this problem.
Add a comment
Chosen Solution
Hi @saulsadiq12 ,
Do you get the "Acer splash screen' on startup before Windows starts to load?
Try connecting an external monitor and check if its display is OK
Try starting in 'safe mode' and see if the screen works.
What OS is installed in the laptop?
Score 1
4 Comments:
No splash screen. Nothing turns on. Just the LED lights at the bottom right.
How do I start it in Safe Mode?
Windows 10
by
Hi @saulsadiq12 ,
Try an external monitor first. You need a screen to be able to navigate to safe mode.
The safe mode suggestion was if you got the splash screen OK but not the Windows screen, in case it was a driver issue.
by
I tried an external monitor and nothing came up.
by
Hi @saulsadiq12 ,
If nothing shows on the external monitor then you have a problem with the motherboard.
Assuming that there are no "beeps" when you start the laptop, the BIOS is detecting the GPU (Graphics Processor Unit) OK but it has no output.
Given the cost of a replacement motherboard it might be advisable to search for a new equivalent laptop.
by
Add a comment
Try connecting the laptop to an external monitor. If everything looks ok, it means you need to get the screen replaced.
7 Comments:
But if it doesn't look okay, do I need a new motherboard? If so, I found for $390
by
You realize for $390, you can get a new laptop right?
by
Not a good one though.
by
You just don't know how to look. :-)
https://www.dellrefurbished.com/laptops/...
I have like 10 of these, and they are like new,
by
Hi @avanteguarde ,
10!!! - are you in the used laptop/ phone/ computer repair retail business then?
If not I thought that I had a problem with collecting / repairing / keeping / not throwing away "stuff" ;-)
Cheers
by
Show 2 more comments
Add a comment
Add your answer
Saul Sadiq will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 267
