1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162 Questions View all
Not working display, what should I replace Display Data Cable or LCD?
Hi guys, my display is not working anymore, the mac is working absolutely fine with an external screen, but I dont know what should replace the Display Datqa Cable or the LCD. thanks
Update (01/22/2018)
thanks for your answer men!, i will doit
Add a comment
Most Helpful Answer
What does the flashlight test show you? Take a flashlight hold it on the screen at a sharp angle (about 20 degrees) are you able to see the faint image of the desktop and the icons? If you do the issue is the backlight circuit on the logic board Vs the display.
Score 2
Add a comment
There is not really a way of telling which it is so I would start by replacing the Display Data Cable and then if that doesn't work then replace the more expensive LCD.
Add a comment
Add your answer
Daniel Murrieta will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 61
