Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
Why my phone gets very hot in seconds and drains insane the battery
My iphone 6s plus does not charging any more and if i put a charged battery it get stuck on apple logo, i can put it in recovery mode or dfu mode( it recognise the cable) but does not connect with the pc, can it have something else than the u2 chip?
Update (01/24/2018)
Now if i put the phone on airplane mode it work fine, even on antutu benchmark with airplane mode off i hot 80000 and airplane mode on 135000, it does not drains battery and does not get hot, can i fix it?
Add a comment
1 Answer
Chosen Solution
Your Tristar (U2) IC is probably damaged. This IC handles all communications with whatever is connected to the Lightning port...that includes the battery charger and computer. However it can happen that the charging is affected but not communications with the computer.
Score 2
6 Comments:
Thanks for help, i took it to a repair shop and they told me its not the u2 ic because its not booting, can there be something else?
by
A failed U2 can also cause boot issues...it depends how the circuit fails. Did they even open it up and take a look at it?
by
Yes, they have change the u2 and now the phone is charging but still not booting or connecting to pc, i am not sure ifthey did it right
by
Since they already changed U2, then tristar isn't the fault here as it's still getting stuck on apple logo.
Have you tried updating the phone first to see if that helps? If you get an iTunes restore error, post it here.
Also if you want you can also try restore but only do that option if you dont have any data to backup from the phone.
by
Problem solved, it was a faulty rezistor and the u2 chip, now it works, thank you for your help
by
Show 1 more comment
Add a comment
Add your answer
Alin Ghetu will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 683
