Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Why is my front camera not working after I replaced battery?
I watched some tips on the youtube which showed how to replace the battery briefly without removing the LCD. I did exactly the process with holding the LCD 90 degree throughout the time replacing. When I assembled the phone, I figured out that my front camera just show a black screen and couldn't take any photo, It still fine when switch the rear camera to the front camera, and the rear camera was fine. One thing I noticed that when I placed the battery inside and run the camera my phone keep restarting few times. I wonder where the problem was? My front camera or when I replaced the battery there was some shorting happened and it affected to the IC on the main board which control the front and rear camera?
Anyone can help me? Thank you so much! Cause now I'm very confusing, if I order the new front camera to replace will it solve the problem? or the problem came from the main board?
Score 1
Add a comment
1 Answer
Chosen Solution
Restarting issue is probably caused by defective battery.
The issue with the front camera is probably the front camera ribbon flex cable assembly damaged. Usually teared.
Score 1
2 Comments:
Thanks for your response ,but I checked the cable meticulously! There was no signal of teared or damaged. Still very confusing what should I order to replace.
by
It's always worth a try replacing the front camera cable even if it doesn't have any signs of damaged. Bending those cables past 90 degrees can damage them.
by
Add a comment
Add your answer
Khoi Nguyen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 13
All Time: 4,877
