Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
Battery problems after replacing lightning assembly
About two weeks ago, I replaced my iPhone's lightning connector and headphone jack assembly. This solved the problems I had been having (lack of response to earbud in-line remote, and earbud audio cutting out when I pressed the Home button), but new, more severe problems immediately emerged. My phone would sometimes turn itself off and then back on several times in quick succession (this problem seemed to toggle when I manually turned it off and on), and the displayed battery charge appeared completely unreliable. The lightning bolt icon would appear when I plugged the phone in to charge, but because of that unreliability of the reported charge, I have no idea whether it ever actually charged. A few days ago, it shut off and simply would not turn on again, whether or not it was connected to power. At one point it briefly displayed the Apple icon when I applied pressure near the battery connector.
I suspect the problem is that the battery is not connected to the logic board correctly. However, other problems I encountered while reassembling the phone included difficulty connecting the antenna (on the lightning assembly) to the logic board (I noticed that it was originally held with a small amount of glue) and difficulty keeping the lightning cable connector attached to the logic board (I successfully plugged it in a few times, but it would detach a few seconds later without apparent cause).
I have also noticed that the lightning assembly which I bought from iFixit is missing a foam pad on the panel which connects to the logic board, and that the store does not appear to sell these separately (as the only foam pads I saw listed for the 5c were for the audio control cable connector, battery connector, digitizer connector, and LCD connector). Would one of the other pads be an appropriate replacement? If not, is there some way I could remove the pad from the old lightning assembly and apply it to the new one?
I would like to know whether my current assumption (battery connector problems) matches up with the symptoms, and whether anyone has any tips for keeping the antenna and connector from the lightning assembly connected to the logic board. Thanks.
Edit: I have padded the lightning assembly connector with masking tape and verified that both it and the antenna cable are securely connected to the logic board. I also disconnected and reconnected the battery to the logic board. Nothing seemed obviously wrong, but when I plugged the phone in again, it shut itself off again a few minutes later.
Add a comment
Chosen Solution
Oh my...I'm sorry to hear that your DIY fix didn't turn out se well.
The foam pad on top of the connector is there to insure that the retaining bracket is applying proper pressure against the connector. Normally, the connector snaps into place and some would argue that brackets aren't even necessary. Personally, I always put the bracket back and insure the connector top has the foam. Those foam pieces aren't always easy to find, at least not locally (easy from China) but IMHO, any foam will do. You can just cut it to size (not while it's on the flex please). You can also try to remove it from the old battery, it should be sticky enough to stick a second time. Otherwise, you can try so put a few layers of masking tape (again, cut to size) to simulate the foam. It won't be perfect but close enough.
Finally, regarding the dock connector. It normally has a lot of "grip" when properly connected. If it isn't snapping into place, then something must be improperly assembled. Double check everything to make sure .
Score 2
1 Comment:
Much of the lightning cable is stuck to the back of the case with adhesive, and I noticed that at first it had ended up in not quite the right angle, and then (after repositioning) that the adhesive had become weaker. This may have something to do with it.
by
Add a comment
Most Helpful Answer
The restarting issue could either be caused by a bad battery or knocked off small components right above the battery connector on the logic board.
The 4 little components right above the battery connector are used to get battery information data from the battery to the logic board.
When they get chipped or knocked off you get random rebooting issues.
Score 4
3 Comments:
Probably the knocked-off components, unfortunately, since the problems started immediately after I reassembled the phone. I'll open it up again in case it's just a faulty connection, but that sounds like I won't be able to fix it myself.
by
Is there any way to visually check whether those components are intact? When I reopened my phone, everything looked okay, but since I don't know how those components are supposed to look or even exactly where they are I can't be sure.
by
Just 4 little components right above the battery connector, like I said in my answer you can't miss it with a microscope.
Their the smallest components on the logic board if I'm correct. Left of the charging port antenna cable and right of the charging port connector.
I've added a link example, it's the purple marked and the components near it:
https://d3nevzfk7ii3be.cloudfront.net/ig...
by
Add a comment
Add your answer
Elizabeth Gauntt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 28
All Time: 183
