Says Ink has run out after cartridge replacement.
Message says my mp160 canon printer ink has run out. Printer off line . These two messages are wrong. I am on line ...and I have replaced the ink cartridges. What's wrong
Absolute con. If you hold down the red sign that looks like a triangle inside a circle for 5 second miraculously the printer resets and you all of a sudden you have inc again. I believe this is a bug that has been put in to stop you buying low price inc alternatives. This happens even on new cartridges if the printer thinks they are non genuine. How is it you can buy a printer new with cartridges for less than the cost of cartridges on their own. Hope this works but if not you have lost nothing.
All the best luck !!!
Jason (The Tower Corisande Manor)
This saved me hours, worked right away. What a cheeky thing to do, only happened when I used recycled cartridges 👀😒 thanks for posting the solution!
Ellen Myrup, give this a try and see if it helps.
for more instructions
Disconnect the power cable
Hold down power button
Reconnect the power cable
With the power button still down, press twice the “Cancel/Stop” red button
Release the power button
The printer is now in factory mode…(wait about 30 seconds until it says “idle”)
Press the down arrow (next to the “OK” button) until it says “Shipping Mode 1”
Press the “OK” Button
Now with it displaying “Without Cleaning” press the power button
A test page should print
Now open cover
Disconnect the power again
Take both cartridges out like normal
Close cover
Reconnect power cable
Press power button
Replace cartridges
The other way to reset it would be by using MPtools and the instructions are here MPtools should have come with your printer. Good Luck and let us know if it worked.
this was ok till I got to the instruction "press :ok: after getting shipping Mode 1 on the screen. Can't get this to do anything - just sits showing Shipoing 1 and pressing the ok button does nothing. Hope you can help, this was/is a great printer and I would love to get it working again
Thanks
Sue
can't even gey "idle" to display , but mine is a MG4250 pixmar printer,. same fault tho
I don't know if you'll still read this, Old Turkey, but I had a problem with my Canon MP-610.
I did what you instructed above. This worked as described (Press the down arrow did not work, but the Right arrow worked), until:
"Now with it displaying “Without Cleaning” press the power button
A test page should print"
It indeed displayed “Without Cleaning”, and I pressed the power button (one time? Or longer? I tried both) but it did not print a test page. Nothing happened, actually.
- So I followed the rest of your instructions. Then it looked like it would print two test pages, but reported that one of my colors is empty, so I have to buy that first.... hope to write later how this ended.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 32
All Time: 14,889
1 Comment
mine is same fault on mg4250 pixmar, tried the above for mp160 can't even get idle displayed. any advice please
by geoff.archer
