Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Why is my phone not making calls, and why can they not hear otherwise?
I recently replaced the battery and the charging port/AUX port/microphone and afterwards everything worked perfectly except now if I try to make a call it will not ring and will just give me the error that the call failed. I believe that I am receiving calls just fine, but if I get a call or if I somehow manage to make a call then the person on the other side cannot hear me very well at all. I seem to be cutting in and out or just not getting sound to them all together. Any ideas of what this could be, what to check or what I should do?
Add a comment
1 Answer
Chosen Solution
This type of repair is not my forte, but is it possible a flex cable or something of that sort was torn in the repair? That seems like a logical source of annoyance after a repair. If you know that's not the issue, I would suggest (from a more solid background of experience than my above suggestion) that you try restarting it with the power/home button restart a few times - I know someone with an iPhone 6 that, for seemingly no good reason, has gone completely nuts on multiple fronts, including being wonky with the actual phone part.
Score 1
1 Comment:
I did a factory reset and the problem seems to have gone away for now, if it comes back then I'll look at the internals again. Thank you!
by
Add a comment
Add your answer
Nathan Arnold will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 12
All Time: 85
