Fans runs at maximum speed as I start the MacBook
Hi Folks!
I've got a problem that is turning me mad, and I passed the last 2 days searching for solutions.
A week ago I started to have the fans in my old macbookpro5.2 running at max speed.
I'm used to open it to clean it and to change components (HDs, ram, battery) and it's the first time I have this problem.
Just to avoid answers with things I already done, I try to be more specific I can.
Since several years I'm not using anymore the CD player, so I have a 2nd hdd instead.
Same thing for battery: several years I'm not using the original one.
Last change I've done: swapped out 2 SSDs and put SSD+HD (samsung 850 evo as primary disc and a 1TB hdd @7200 rpm for data).
The fans runs at maximum since I start the computer, so it's not a temperature issue (as I write below).
Until now I've done:
1) resetting both NVRAM AND SMC. The first time I've done the SMC I saw at the first reboot that keyboard lights blinked several times and then also the fans started at maximum, then slow down, then maximum, slow down a few times and after then they were always at maximum speed.
2) Detached the second hdd because I read somewhere that this could be an issue.
3) Already cleaned up all fans from dust
4) phisically detached and reconnected the battery, pressing 5 sec the power button to hard reset the SMC
5) detached the fans and reconnected
6) run the AHT (Apple Hardware Test): this gave me an error but I found out this is common if the battery is replaced (and resetting the SMC after the test hasn't lead to anywhere, I've got the same error).
7) run the ADVANCED test from AHT: almost 3 hours running to find always the exact same error code:
4SNS/1/40000000: TB3T-128.000
NOTE: only this error is found.
8) installed BOTH istatmenus and SMC fan controller, and with both, I can't control the fans. I've tried to make new adjustments but it was useless.
9) changed the SSD
10) tried to upgrade the SMD firmware but no need to upgrade anything.
I've tried hard to find a solution, also taken a look at your forum, but with no luck.
I've got no CPU usage, no new software, no strange sensor measurements, no battery issues.
I attach also a little screenshot of istatmenus sensors temperatures:
https://s26.postimg.org/57t3uhzt5/Scherm...
I suspect a sensor failure, but where is it? I read there are more than 1 and it's not so clear where they are.
Another possible solution could be replacing thermal compound for cpu/gpu, but before disassemble all the machine I want to verify all the rest (and honestly I'm not convinced the problem is this).
I'd appreciate a lot your suggestions.
Machine:
MacBook Pro 17” Unibody early 2009
Model Name: MacBookPro5,2
Model A1297 (EMC 2272)
CPU: Intel Core 2 Duo @2,66 GHz
Cache L2: 6MB
RAM: 8 GB
SMC Version: 1,42f4
EDIT 1
from image posted I can see no Palm rest temperature is present. Could that be an issue?
2 Comments
Are you using any fan control software? Have you tried booting up on an external drive which has a clean OS (nothing else) what happens then?
Did you get your system wet or spill a drink into your system at some point?
by Dan
Please refer to point 8)
Tried 2 and not working. The system is CLEAN: I installed it from scratch. Only VLC present by now.
No system wet/spills: I treat my computer very carefully.
Thank you! :)
by Riccardo
