Repair guides and support for LED, LCD, HD and other Vizio TVs.
933 Questions View all
Vizio M55-C2 No Picture, Has Sound, Backlights Work
I recently purchased a cheap Vizio 4K led tv in the hope of fixing it. The model is a M55-C2 and the previous owner had it for one year mounted on his wall. The power light turns on and it will either flicker the Vizio symbol for a 1/4 second or be blank when turned on. When I say blank I mean a extremely dim/blueish version of what’s on the screen. Here’s a really interesting part. I can hold the mute button to turn the backlights and panel off (audio only mode) and once I do I lose the dim/bluish picture and just I get a black screen. I then hold the back button to get out of that mode and I get a clear, perfect picture of what’s being played for half a second. It then immediately goes back being dim. I can also get a picture for half a second by unplugging the LVDS cable and then plugging it back in. The sound works perfectly and all the backlights work (removed panel to take a look). All the voltages coming out of the power board seem normal. I called 5 tv repair places and told them my situation and they had varying answers. They said it could be the t-con, bad panel, mainboard, or the backlights. I replaced the t-con, LVDS cable (t-con to main), and currently have another mainboard coming in the mail from Jimmy. They sent me the wrong board in the right box last week. I’m having a lot fun playing with this project but would like to see some progress. The biggest fear is that it’s the panel but I don’t know how it could be if I get a clear picture for half a second. It almost feels like the panel isn’t getting the power it needs. Any help would be much appreciated.
Score 3
Add a comment
Most Helpful Answer
@answerorhelp that is a tough one but it does sound like an issue with the main board since you are getting the backlight. Now you do want to check the voltages to the main board from the powerboard. The required voltages should be marked on the board. If your power board does not supply that, your main board can not generate the picture. I guess right now it's best to continue the way you are progressing. Once you got the new main board let us know what you get.
Score 1
6 Comments:
Thank you for the reply. I have checked the voltages from the main board to the power board. These are the results while the tv was on and playing a movie.
Pin 1 5vsb. I get 5v
Pin 2 5vsb. I get 5v
Pin 3 AC DET. I get 3.27v
Pin 4 PS_ON. I get 3.27v
Pin 5 GND
Pin 6 GND
Pin 7 12v. I get 11.87v
Pin 8 12v. I get 11.87
Pin 9 GND
Pin 10 GND
Pin 11 12v. I get 11.87v
Pin 12 12v. I get 11.87v
I should also mention that the highest voltage I have found going to the panel from the t-con is 3.3v. I don’t know if that means anything.
by
@answerorhelp those are looking good. We'll have to wait for the Main board to arrive to see if it works.
by
Updates
So I ordered a mainboard from Shop Jimmy based on the pictures and the model numbers they had listed. The first one arrived was for a vizio D65-D2 tv. So Jimmy sent me a second one and it was also for a D65. Jimmy admitted to the mistake and removed the main board I was trying to order from their website. They better be giving me a full refund. Today I called vizio to locate the exact model I need and I’m currenly waiting on them. It should also be noted that the serial number on the back of the tv is LWZQSBBS. This serial is apparently a bit uncommon. Current goal is still to get a mainboard. Will keep the internet updated.
by
Update. I ordered a maninboard a few weeks ago and tested it out and of course it didn’t fix the tv. When I did the mute and then back button combination to see the image for a split second the image was also upside down. In the end I’m deeming this tv unfixable by me. I think something went wrong with the panel. It should also be noted that vizio could not locate the correct mainboard for this tv. They also told me to just go buy a new tv. So don’t buy vizio. Stick with Sony, Samsung, and LG.
And get a warranty.
by
Thanks for posting this, I have the same issue with my Vizio M55-C2 I didn’t know about the holding the Mute button I will try that when I get a chance. I know this post, and my TV is old, but i hate to throw away more e waste if there is a fix. did you ever get it working?
Thanks,
Matt
by
Show 1 more comment
Add a comment
I had the exact same problem! The TV will turn on (power LED on and backlight turns on), but no picture appears. The sound will work through the inputs. The remote is able to turn the TV off and on. The mute-hold trick to turn the backlight off also works, followed by the back-hold trick to turn the backlight on.
I ordered a replacement T-Con board, power supply board, LED driver board, and main board for my Vizio M55-C2 via ShopJimmy. I swapped out components one-by-one, and it turns out that the power supply board was to blame. I didn’t check which voltage rails were suspect on the board, but it’s clear that the power supply was partially working.
(ShopJimmy shipped a broken/incompatible main board, so that made my troubleshooting more difficult.)
Replacing the power supply board with a new one fixed everything. Hope this helps someone in the future!
Add a comment
Those comments were really helpful.
I'm having the same voltage results except for the PIN 4; I'm getting 3.14 volts. If that's normal then I need to replace the motherboard I guess.
Add a comment
Add your answer
Charlie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 2,703
