Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Non charging when screen replaced, no screen works
hey guys,
changed my screen and since no screen works, even the old ones i have.
phone didnt charge or anything because i had a iphone 6s home button so i turned off everytime i plugged the home button connector inm,
now i replaced with normal 6 home button the phone is reconized by itunes but no screeen at all works
what could have happened?
Add a comment
1 Answer
Chosen Solution
Just to confirm, did your original screen work (backlight, image) just prior to the repair? And then after you replaced the screen, now neither the replacement nor the original screen light up?
If that's the case and your phone is recognized by itunes, then you may have damaged the backlight circuit on the logic board. This would require a micro-soldering repair.
Score 2
Add a comment
Add your answer
ferrarienzo7 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 32
