Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 Questions View all
LCD is black, but boots, and shows on external screen
Hello everyone,
I have this iMac from 2011, and my LCD screen stays black after booting up. However, when I attach an external monitor, it does startup and work perfectly. The only thing is noticed was that the 4th diagnostic LED is not lighting up.
You would think it's the LCD panel right? Well, I've switched the screens with another iMac, and it works fine. So it is not the LCD panel. Then I've started switching other parts aswell, checking if something changes, or if any part is broken. The LED backlight board is fine, the cables are fine, the LCD panel is fine, it does get power and I assume the Logic Board is fine aswell because it does boot and work normally (even though it has a black screen).
Does anyone have a clue why it does work on an external monitor, but the LCD just stays black?
Please let me know!
Add a comment
1 Answer
Hey Stijn, sorry to hear about your screen! Have you looked as the sensor that tells the computer if the lid is shut or not? Thats the only thing I can think of. If the back-light is indeed getting powered then it should be working unless the screen is bad. Did you try testing the screen in a different computer or did you put in a new screen?
2 Comments:
What lid on the iMac do you mean? And yes, I have tested the screen in another iMac and it worked perfectly, so that is not the problem.
by
Sorry forgot I was talking about iMac here. Thats a really weird one, I would just keep trouble shooting, the answer will come. The way you explain it, it sounds like a rabbit hole question. Good Luck To Ya. Hope to hear the solution when you find it.
by
Add a comment
Add your answer
Stijn Nijhuis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 115
