A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
971 Questions View all
My Toshiba satellite C55- B5382 will not power on please help!
As stated in discription my Toshiba laptop will no longer power on. When the issue first started it would power on sometimes and then finally a few months later it just powered off in the middle of my daughter using the computer. When I plug in the power cord the led light comes on that its charging but when I press the power bitton the power light stays on maybe 5 seconds, never makes the booting on sounds, the fan doesn't start, ot doesn't even try to boot up. The power light just comes on briefly and then goes off. I use this laptop for my daughter's homeschooling and medical care so if you have any idea how I can get it working again please, please help! Unfortunately, I hadn't backed up any of my data so its important that I fix this issue ASAP..... thanks in advanced!
Add a comment
1 Answer
If you have a second computer, you can simply take the broken Toshiba's hard drive out and place it into an enclosure to retrieve your data.
https://www.amazon.com/Sabrent-Tool-free...
Regarding the laptop itself, it sounds like something on the motherboard is going bad. See if there are any bad capacitors, or take it to a repair shop to investigate this.
Add a comment
Add your answer
Davina will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 611
