What made a loud pop and now no sound or picture?
My tv made a loud pop sound and then the tv went off. It will not turn on now. What is wrong?
Tracy Weaver could be an issue with the capacitors, fuse or the relays on your power board. To properly determine what is going on w will have to take a look at it. Unplug your TV and post some images of all off your boards with your question. That way we can see what you see. Use this guide Adding images to an existing question for that
I turned off the surround sound and turned on the volume leveling and it stopped.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 6,355
2 Comments
Our TV makes a pop sound and volume goes off, not TV.
by Michael Hirsch
@Michael Hirsch
The "pop" sound may simply be the audio being removed suddenly.
Does the audio come back by itself or if not how do you restore the audio?
What is the source of the signal e.g. TV antenna, cable box, media streaming device etc?
If from a "box" of some description, try a different input on the TV or input type between the box and the TV e.g. if HDMI change to a different HDMI input on the TV or change to Component video + audio between the box and the TV.
Try a different signal source e.g. dvd player and check if the audio remains on or also turns off when using it.
Basically trying to find out if the problem is the TV or the signal source.
If the signal source is a TV antenna than it is the TV.
What is the model number of the TV?
by jayeff
