The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Trackpad stops working, even after full wipe/recovery install
So there's a ton of questions and answers on here, many coming down to possible issue with ribbon cable for track pad, or update to newer version of OSX, etc. Basically, on a friend's 15-month old MacBook Pro, trackpad just stops working (no haptic response when using it, no movement no pointer, etc). I did a clean wipe/install/updated her to High Sierra, and after about 8 hours, it finally reoccured after laptop was closed. Weirdly, then I plugged in a USB mouse, and 30 seconds later ... trackpad was responsive again -- and at the same time the computer brought up the mini pop up saying keyboard wasn't recognized, even though i did not attach an external keyboard. Does this particular behavior indicate anything to all the smart people who know this stuff much better than I do?
One quick addition: If this is a loose cable, it's pretty amazing that it worked all day and then stopped and then, without computer moving a hair, started working again.
Score 1
4 Comments:
Did your friend buy this system used or reconditioned? It can't be 15 months old if he bought it new ;-}
by
Well he bought it for his daughter who started high school last September ... so that's around then! He bought it new from the Apple store here near us. Thanks for the email below, I did read about the ribbon cable, i found it online. I wonder what the genius bar will say -- and what they'd charge to fix/debug ... thanks again!
by
Sounds like he got it just before the 2016 models came out. Did he get AppleCare for it? If he did then he might want to let Apple fix it (free)
by
Alas, no AppleCare. They do have an appointment for the genius bar in a few days (very busy this time of year) to see what Apple says. Today it locked up totally, keyboard and trackpad. Are they both affected by the same cable, do you know? Also, it seems so strange that if it's a bad cable, that ... resetting the NVRAM would fix it temporarily (which it did). Oh well ... thanks again for our help, I found the cable and ordered it and if Apple says this will be a $600 repair or something, I'll give that a shot first most likely.
by
Add a comment
1 Answer
Your systems design has the trackpad cable riding on top of the battery. If you review this IFIXIT guide: MacBook Pro 13" Retina Display Early 2015 Trackpad Replacement Jump down to Step 7 to pull the cover plate, then jump down to Step 17 which walks you through the removal of the ribbon cable. I would start there MacBook Pro 13" Retina Touchpad Flex Cable, Early 2015
A common issue is liquid damage. This could even be someone using a spray cleaner onto the uppercase which seeped into the trackpad and/or keyboard. I always recommend spraying the cloth then wiping the case with the dampened cloth.
As your keyboard is also fritzi, this could be a swelling battery which is pressing on the cables. A good inspection should tell you if its blistered up. I would run coconutBattery to check the batteries health.
Let us know what you find
Add a comment
Add your answer
jctracey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 424
