Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 Searching / No Service
Hey, My 2 year Old IPhone 6 cannot seem to get any service I have tried the drop method which does work But only for a small period of time .The phone recognises when the sim is in or out of the phone ,I cannot get the imei number when I call *#06# But can get it in settings. The phone previously had problems with The Touch ID and Charge IC On the motherboard Randomly Breaking and not working but I got them repaired.If anyone has any idea what this is Please let me know ,
Thanks
Add a comment
Chosen Solution
This is an issue with the logic board relating to the baseband chip area. You will need to take it to a micro-solder to fix.
Score 2
3 Comments:
How does this Chip just break by itself for so many people and why does it sometimes work when dropped?
by
This occurs because most of the major chips on the logic board on iPhones are BGA mounted (ball grid array mounted) meaning they basically sit on an array of solder balls. Also the design of the phone is pretty thin.
This is vulnerable to bad solder joints that break with lead free solder and as you know the iPhone 6 frames bend too easily which can make this issue occur easily.
by
For the OP...additionally, there are two copper traces underneath the Baseband IC that tend to crack from all of the drops, impacts, flexing and twisting. These have to be solidified.
by
Add a comment
Place the non-original chip (ie, a chip other than the bracket on which the device is locked) and connect the device to iTunes through a USB connector. When the device is detected by iTunes, back up and select Restore. (Try restoring without holding Shift / Option, or place the iPhone in DFU mode to do this.) After the restoration process, you will have two options: Restore from a backup and Setup iPhone as a new phone. Choose the second option. After selecting the second option, you must skip the activation steps. After the completion of the activation steps must appear (if nothing happens, repeat the steps)
Add a comment
Also, There is something thing loose inside the phone if that has to do with anything?
Add a comment
Add your answer
Aaron Clarke will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 4,148
