Repair and support information for HP Laptops, designed for home and home office use.
Change HD to SSD and upgrade RAM
Hello,
I have HP x360 13-s102TU touchscreen laptop. Currently it has 1TB hdd and 4 GB RAM. I wanted to check whether it is feasible to change the HDD to SSD and upgrade the RAM to 8 GB.
I was checking over internet, but havent found any substantial support in this regards.
Else, the only option remaining is to open the laptop and check.
Hoping for a solution on this.
Regards,
Rohan
1 Comment
Add a comment
1 Answer
Chosen Solution
Max RAM 8 GB 1x1 PC3 12800
Looks like you are good to go for under $200
Score 3
4 Comments:
Thank you @j0vian for the quick help. Can you tell me whether there will be a remarkable improvement in the system performance after this change in terms of using lightroom and photoshop?
by
There should indeed be a remarkable improvement.
by
Considering OP has a 5400 rpm HDD an SSD should be an extreme improvement.
by
@rohankonge If satisfied with the answer please choose the answer as the chosen solution so the problem will be marked solved. Thanks
by
Add a comment
Add your answer
Rohandeep Konge will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 737
