Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
75 Questions View all
How do I remove a (somewhat stripped) screw that is stuck?
In order to replace the palm rest I have to remove all the internal components but a few of the screws holding the motherboard in place are stuck.
How do I remove this screw without damaging the motherboard?
Add a comment
1 Answer
Most Helpful Answer
Sounds like you used the just slightly wrong sized philips screw driver.
This probably caused the stripped screws.
You can get a set of strip screw removal tools.
https://www.amazon.com/Moody-Tools-58-06...
Or if you have a small enough dremel you can simply remove the heads of the screws.
Score 2
Add a comment
Add your answer
Jelle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 651
