Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
New battery installation questions
1. I changed the battery last night. everything went ok except had trouble getting the adhesive strips to stick to the battery. they came loose before inserting into the phone and got a little balled up. I straightened as best as I could but they still had a "wad" in the middle but, not having any more strips, I installed anyway. what problems might this cause down the road?
2. the new battery started at around 47% so I'm letting it discharge to 10% before re-charging to 100% per instructions. However, it seems to be discharging more rapidly than expected. Is this normal on the first cycle before the battery is "trained"?
Add a comment
1 Answer
Chosen Solution
1. Shouldn't be any issues, unless the battery does not seem to stick to the iPhone housing
2. Personally I do not bother with this stuff, I just use the phone as usual.
Try restoring the iPhone, make sure you backup your phone via iTunes first before you restore the phone as it wipes all data on the phone, it may help with rapid battery drain.
Also did you check the battery health of the previous battery?
Use either one of these methods to check your battery:
Windows PC - 3UTools
Mac OS X - CoconutBattery
Using mobile app - Battery Life
Replacement batteries should not be draining fast, could be a defective or refurbished battery.
Score 2
2 Comments:
The bottom 2/3 of the battery is stuck to the phone but when the tape got twisted up I couldn't stretch it back up to the top. Replacement battery is new, I didn't check the old one, it had been in use for about 1 1/2 years and the phone was starting to respond slowly. I'll see what happens. Thanks for the response.
by
The battery adhesive should be fine, as long as you don't see any marks on the screen which would indicate the battery pushing against the screen.
For the old battery, don't worry about that for now as it seems like the old battery is worn out.
by
Add a comment
Add your answer
Michael Potash will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 58
