Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
iPhone 7 LCD brightness
Hi Guys,
Wonder if anyone has experienced this issue.
I have noticed a few times after replacing an iPhone 7 screen with an OEM screen, the maximum brightness can vary. This can sometimes even happen when installing the original Apple screen again.
For example: if you turn the brightness up, most of the time it will keep getting brighter until it gets to the maximum level, but sometimes when the brightness is only at 80% level then it won't get any brighter after this point, then while you're using the phone the screen could suddenly become brighter because the brightness is at maximum level.
Hard to explain but hopefully you guys have either experienced this yourself or i am explained it good enough for you to understand.
Thanks in advance.
Add a comment
1 Answer
Chosen Solution
My guess it's the auto-brightness varying when removing the front camera which has the ambient light sensor on it and putting it back on.
As you may know already the fit for the ambient light sensor would not be 100% perfect once it has been removed before so auto brightness will vary across screens and after the front camera has been removed.
Score 3
Add a comment
Add your answer
chilun will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 110
