Repair guides and support for your LG TV.
1343 Questions View all
Power on - last channel
Hi.
I have a LG TV.
If, for example, I am on channel 10 and I turn off the tv, when I turn it on by pressing a physical channel button 1-9 on the remote, it will be opened on channel 10 so it holds the last viewed channel.
How can I change this and make the tv to power on the channel I press from the remote?
Thank you!
1 Comment
@deyu1s what model LG TV and what model is your Remote? Are you using a cable box or how are you connected?
by
Add a comment
1 Answer
Chosen Solution
Hi @deyu1s ,
You cannot change this to do it your way. (Unless you wish to rewrite the firmware)
The firmware is written so that the TV stores the last channel that it was on when it is turned off and will connect to this channel first regardless of the way it is switched on.
The correct way to turn on a TV is to use the TV's Power On button or the remote control's On button, not the channel number select button(s). That is what the On/Off buttons are there for.
Score 1
1 Comment:
I purchased a new LG TV and Xfinity is my TV service provider. When I turned on the TV using my Xfinity remote, it went to the LG dashboard channel. If you turn off the TV and turn it on using the LG remote you will arrive at a screen that allows you to select Settings on the left. Click on Settings, then General, then System, then Additional Settings (three dots), then Home Settings. A screen with Home Auto Launch and Home Promotion comes up. If they are green (active), click on the green to make it turn gray. Turn off the TV using your LG remote. Use your Xfinity remote to turn on the TV and it should go to the last channel you viewed. You should use only the Xfinity remote and it should return you to the last channel every time.
by
Add a comment
Add your answer
Andreea will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 28
Past 30 Days: 111
All Time: 2,430
