Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
Tablet not coming on or charging
My daughter's tablet stopped charging it just flashes the charging battery screen on and off but will not charge or come on having same problem with my 10 inch RCA tablet it won't come on or charge either tried multiple chargers and no difference.RCA wouldn't fix or replace either store replaced the first 7inch which did same but won't do it again my wifes7inch RCA tablet has same model#as I stated but with "B"at end of w22 and the top half inch of screen doesn't respond to touch commands .. please help us...
Score 2
1 Comment
I would recommend taking it to your local tablet repair shop
by
Add a comment
Chosen Solution
Hi @dirtysouth1978 ,
With the tablets that have the charging problem try leaving the charger connected for at least 3-4 hours to see if the tablet "kick starts" into charging the battery again. If it does start to charge let it fully charge before disconnecting the charger and attempting to turn it on. Apologies if you have already tried this.
With regards to the tablet with the faulty digitizer (touchscreen) here is a link to the ifixit RCA Voyager II RCT6773W22 Disassembly guide which shows how to remove the digitizer.
Here is a link to a video which shows how to remove/replace the digitizer which may also be of some help.
While the above two links are not for your particular model variant they should be close enough to be relevant.
Here is a link to just one supplier of the replacement part. It is not a recommendation to use them. It is shown to give an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for RCT6773W22B digitizer replacement part
If you find the repair process too daunting contact a reputable, professional mobile phone repair service and ask for a quote to repair the tablet. At least you already know the retail cost of the part. ;-)
Score 2
Add a comment
I have had two RCA tablets that do this, plugging in the AC charger doesn’t charge, I only would see the battery symbol on the tablet. I found that if I used a battery power bank and charged it from there, the battery indicator on the tablet screen would now show a percentage charged… Once it was above 5% charged, I can then switch to the AC charger and it would fully charge and operated normally. I am guessing that letting these battery completely drain is not a good thing…
3 Comments:
Mine is doing the same thing...What is a battery power bank?..I bought this less then 3 weeks ago.
by
My RCA tablet touch screen laptop keeps clicking when it’s on the charger and it won’t turn on even though the blue light still turns on. What do I do to try to fix it???
by
Mine is doing same thing but no light
by
Add a comment
Add your answer
Jessica Blake will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 11,638
