Why does my power on button not work?
My MacBook Pro (late 2008) increasingly refuses to switch on - ie as if battery removed. I have tried every tip going. Sometimes it works sometimes not. Generally if used daily or put to sleep it’s fine, but if shut down overnight it’s dead. I have removed the keyboard connector from the motherboard and refitted, which worked yesterday. Did a clean install and it hung, rebooting at start up screen. Had to force shut down as it got too late. Today nothing. Tried removing the keyboard truck but no. Any thoughts? I’ve successfully powered up from power up terminals on the motherboard yesterday so not sure where the issue is. Maybe it’s just died! Got a new battery and replaced hard drive a couple of years ago. Backed up before I started.
6 Comments
Lets' see if your MageSafe charger & battery are in good shape. Download this great free app: CoconutBattery and paste a screen capture of the main app window in your question so we can see what it tells us.
by Dan
That’s not the issue. Charging is fine and so is the battery, so are the indicator lights. Am I replying to a product promo?
Is there a way to test the power on button (not the MagSafe charger)?
by Clive Dorman
I'm not a product promo person, I have no interests in the product. What I do have is the willingness to help others save their systems.
Given the problem your stated this is an important diagnostic process to remove possible issues. More often than not power problems can be the root issue.
Did you have a liquid spill or sit your system down on a wet surface?
by Dan
@danj isn't a promo person. Coconut battery has helped many others with battery issues. what it does is gives you the number of charge cycles on the battery, the current health of the battery and other stuff. also a promo person would not have 200,000+ reputation. just click on this-----> @danj for info about him.
by Aiden
Apologies guys, this is my first post so not familiar with contributors. I’ll download the app and try. Not possible if I can’t switch it on the laptop and I need the app on that machine. Also it is a wiped hard drive waiting for an OS! Appreciate the help.
by Clive Dorman
Show 1 more comment
