Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
iPhone saying Connect to Itunes in setup.
Hey all! I have a iPhone 4 that says "Connect to iTunes" In setup. When I do it says There is a problem with your iPhone. This phone has never been dropped and never encountered water. The IMEI DOES SHOW when you hit the blue I But the iccid does not. Thanks!
Add a comment
1 Answer
Most Helpful Answer
first step, is enter DFU mode, and run a restore. A restore is better than a reset, as it installes all new firmware, rather than utilizing the current firmware. should you have a corruption in the core files of your firmware, a reset will not fix it, while a restore will.
To enter DFU mode, follow these steps
1) Plug in the device.
2) Power down the iPhone
3) Hold the power button until you see the apple logo
4) without letting go of the power button, hold the home button for 10-15 seconds. (until the screen goes black)
5) Without letting go of the home button, release the power button, and continue holding the home button for 15-20 seconds.
If you have done it correctly, your iphones screen will be pure black, and your computer should be installing driver software.
From here, run the restore process, as instructed on itunes.
Score 1
4 Comments:
I have already tried this multiple times. But thanks for your help!
by
then from there, with a device of this age, you are likely looking at board degregation. The Apple server will always verify the install, and if it feels the board doesnt have the proper hardware, then it will cancel out. this can be either a third party part or cord that causes the issue, or even just the components on the board reading above or below the voltage threshold they are supposed to.
by
So basically the board is shot??
by
essentially, that is the highest likelyhood. but you can look into things like custom software loading, and the like. i dont have that kind of experience, as i deal strictly with OEM software work.
by
Add a comment
Add your answer
Ethan Leroux will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 164
