S-E error won't go away Hakko FM203
I've tried unplugging and replugging the tips to my new FM203 but the error message won't go away. How can this be fixed?
Two things to look at are the tips themselves and how they are inserted in the handle and the black connector that connects to the actual station. The S-E error is usually caused by a tip that is incorrectly inserted in the handle. Take it out and push it back in completely, it should audibly "snap" into place. If you have more than one tip, try those as well. If none of the tips work, then check to insure the black connector at the end of the handle is properly connected into the station.
Do you have other handles or tweezers that you can connect to the station? This will help you isolate the issue even further.
PDF version of the manual.
This "snap" may take more force than you anticipate, and there can be some false spots that you feel like it clicked into place and then you power up and there's the dreaded S-E all over again. I almost sent back my soldering pencil because of it. Then I really pushed and CLICK! Don't be shy!
One tip: If you can pull it out fairly easily from what may feel like it's in, it's not. I slightly further bent a T15-J02 tip using a wooden benchtop to push. That's the kind of force to anticipate. And once it's in, it takes real force to get it out.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 52
All Time: 3,732
