Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Questions View all
How to identify a broken (? )logic board / power component.
My mid 2014 MBP had possible (??) water damage after a water pipe burst where I'm staying while overseas. There were a few drops of water on the outside of the case, hinge side, but there was no sign of water internally. However it won't power up and the MagSafe DC-in plug (60 watt) has no indicator light when connected and powered up. I took it to the local Apple service centre but all they told me after checking it was that it must be the logic board since it wouldn't turn on but couldn't give me any more details other than that.
Is there a way to tell if it is a faulty logic board or which component on the board is faulty, if in fact it is the board that's US in the first place, or a way of at least ruling out what components aren't at fault? I'm not too keen on automatically replacing the board when I don't have a lot of confidence in the expertise of the local Apple techs, especially when they didn't seem to have any real idea of what the problem was other than the laptop wouldn't turn on.
The battery is the original one that came with the laptop when new. There has been no problem with it up to this point although there is some slight swelling apparent which may be normal for its age. Any advice or suggestions would be appreciated. I'm trying a few of the fixes that have worked for others but no luck so far. Thank you.
Sky P
1 Comment
Joe & Oldturkey3,
Thanks for the feedback and advice. Working on a solution now and will update.
Cheers, SkyP
by
Add a comment
Most Helpful Answer
My experience with water damage is to remove everything and clean the boards with a toothbrush and 92% rubbing alcohol . You may have to replace the keyboard and the mag safe board. Guides are available on ifixit.com for teardown.
Score 1
Add a comment
@skyp you'll have to take a look at the board first and see if there is any obvious damaged component. For that you will have to use these guides MacBook Pro 13" Retina Display Mid 2014 After you have it apart, clean everything with 90%+ isopropyl alcohol and post plenty of pictures with your question. That way we can see what you see. Use this guide Adding images to an existing question for that.
Yes there are ways to determine where the error is and what component. But for that you will have to have the schematic, a boardview for the component identification and a good multimeter. Of course, you need to be able to read schematics and how to use a meter. If nothing else try to contact @reecee @teetopp or @tcrs_circuit who specialize on that type of repair.
Score 1
Add a comment
Add your answer
Sky P will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 998
