2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Determining what to replace when USB port doesn't work.
The USB 3.0 port on the right side of this unit doesn't appear to be working. Plugged a Logitech Unifying transitter, which was not recognized. Tried a USB external Hard Drive to no avail. Same with two different external USB DVD drives. All of these devices work on the USB port off the left side of the unit. I dont think there is any power. I tried reseting the SMC and NVRAM, but those fixes didn't work. For the moment, we are using a USB port expander on the working USB port.
Nothing unusual with the unit. No spills or drops. Just sits on a desk and has been a very reliable unit. We replaced the Lithium battery and one fan a while back. It's worked fairly flawlessly.
Basic question: What's the best way to determine what needs replacing? I looked at the I/O board fix, which suggests two cables and a small I/O board. Unclear if I need all of them.
Is it possible there is something more simple that can be done?
I don't want to spend a lot of money if I don't have to.
Score 1
Add a comment
1 Answer
Chosen Solution
Look closely at the cable connector with a loop glass or magnifying glass for burnt spots. If you find any burnt spots or broken connectors then you can replace the ribbon cable. If not I would go ahead and replace the ribbon cable and the usb board.
Score 1
Add a comment
Add your answer
David C Black will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 73
