Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1526 Questions View all
Screen Problem, vertical stripes
It was not reseting (error 4005), I replaced the battery and did reset without screen, and it worked. But when I plugged the screen back in, I got this strange issue. Note that the phone never hit the ground, it's in perfect conditions. I've tried to disconnect and reconnect all the cables, but nothing changes. Any clues ?
https://imgur.com/a/0VjPp
Add a comment
Chosen Solution
Update ! I already had the cables properly connected. I just asked for help in a local store, they told me that should just be static electricity (?) stored in the screen. In 1 week it seems to have discharged itself, and now the screen I working perfectly. Hope this helps !
Add a comment
Most Helpful Answer
Either the screen is not plugged in properly or the screen is damaged.
Unplug the battery and plug it back in and see if that helps.
Score 2
2 Comments:
It's kinda strange here. This does not resolve the problem, but when I only connect the screen cable (so 1 connected and 3 disconnected), the screen shows the same, but with more pronounced lines. And now that's what happens when I plug it all back in : https://imgur.com/a/NAfmS
by
the cable is not seated properly, try cleaning out the connection on the board and ensure the connector from the screen is flat (not bowed) before installing
by
Add a comment
Add your answer
Talerant will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 5
All Time: 157
