Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Fix battery dying too soon and going into Infinite loop?
The battery dies at around 47% and goes into an infinite restart loop unless I charge it then it starts charging and functioning normally. And it gradually each day has less charge and starts dying, for example, 47% today and probably 50% in two days and so on. Funny because the battery I am using is from ifixit! I did everything right to install it and calibrate the battery and was very careful!
Add a comment
1 Answer
Chosen Solution
Your battery may be defective. To be certain, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). It will tell you what the health of the battery is. Anything less than 80% of design capacity will require replacement (contact iFixit support).
Score 3
1 Comment:
Okay THANK YOU! Will checkout those programs and let ifixit know if it is defective!
by
Add a comment
Add your answer
Raphael Jordan Marcelo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 139
