Can I replace my EMC2309 Logic Board with the EMC2374?
I have a late 2009 iMac with a slow E7600 CPU. I'm beginning to learn software development, and am focusing on the android side of mobile apps for the coming few months; however this will shift to iOS development after that. I am trying to setup my system to be good enough for compiling Xcode without wasting too much time.
This is a shoe-string budget situation. If I had the funds, would purchase a new macbook/imac. I'm broke, and have been gifted this iMac as a start. Had an SSD lying around, and two additional 2GB modules, so it should suffice to start, but the CPU is just dinky. I can go from a C2D dual core to i7 quad core, theoretically, by exchanging the logic boards. They appear to be the same physical dimensions based on the pictures I've seen of both. Is this correct?
I've already opened her up to replace the 3.5" with an SSD. Not an issue doing the surgery. My question is if this is technically feasible. I understand there is a TDP difference of 30 watts, but am willing to give it a go as my current CPU barely registers a temp differential between idle and several minutes of Prime95 load. It appears there's headroom here with the current cooling solution. Are there, for instance, physical connectors which will be differing?
The logic boards appear to be had for less than $100 if you look deep enough. I want to do this in the coming weeks, but can't afford a waste of an investment. Can I have success here? Stories to back up the claims by chance? I couldn't find anything on upgrading logic boards. Perhaps this is around I just didn't dig enough?
It seems they use the same power supply, and upon inspection of the images further, the same connectors as well. I will attempt this if someone can't provide reason why not.
6 Comments
Get the OWC sensor its better!
FanControl slows your system! As it needs to do an IRQ to gain access to SMART. Then it gets into the frequency of checking which gets into the speed of it kinking in. In some cases it won't! Thats why Apple didn't use it.
by Dan
Thanks for the info. In that case I'll just disable SMART sensor and set the fan manually. There's no reason to attach a sensor to a SATA SSD.
by Brandon Chapman
I wouldn't do that either it's more complex than just the HDD heat (SSD if you swap) SMC manages all of the fan's so if you manually set things you could overheat the CPU.
Yes a SSD runs cooler but as I explained I would hang onto the HD if you are planning on doing software development. One tends to build up a sizable library of code snippets and finished apps which you'll want to have. So while a SSD is a great drive for running apps and compiling you'll want to leave as much space free for virtual RAM. Unless you've got a 1 TB SSD you'll want the dual drive setup.
by Dan
There's zero chance of harming the CPU. Each device has independent sensors and configuration. Really, this is a total non-issue. I have a little monitor on the CPU and it has never broke 40C. As for more data, I have a 120GB device that is far more than I'll ever need. I don't store media on this device. If need be I can push data to a secure server in a DC. 1gbps fiber has its perks รท) As well I have my own git server setup.
by Brandon Chapman
I think you'll need to review a schematic as you are correct there are numerous thermal sensors, they are all inputted into the SMC system which then controls the fans.
Sometimes us old timers (over 45 years) know a bit more here... Trust me! you want put back the sensor so the SMC system works correctly. Don't be 'Pennywise, Pound Foolish' here all you do is kill your system sooner.
by Dan
Show 1 more comment
