Repair and disassembly guides and support for dish washing appliances.
705 Questions View all
GE Dishwasher Won't Heat/Steam/Dry
I have a GE Dishwasher model GDF570SGF0BB that's barely 4 years old. It has stopped heating and drying dishes. The steam function no longer works either. I tried the obvious things like cleaning all filters and replacing the heating element. When that didn't fix the problem, I pulled the circuit board out and tested what I could -- it was all fine.
I will go ahead and replace the board anyway, but if that doesn't do the trick I will have run out of ideas. Suggestions?
Add a comment
1 Answer
Most Helpful Answer
I had the same problem.
From all the forums I read, seems to come down to 1 of 3 things: Flood switch, thermostat, or the heating element itself. The flood switch is the easiest to replace since you don't have to take the whole dishwasher out to replace it.
In my case, once I replaced the flood switch, I was back to normal again.
Score 2
Add a comment
Add your answer
SFL will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 3,051
