Can you upgrade the storage?
On the hp 11 g5 chromebook it comes with a 16gb emmc or ssd. Can you upgrade this with a seperate bought emmc or ssd.
I Believe you can put an SD card in the side to expand storage. But I don't know the answer about the internal upgrade. I've opened up a chromebook before and it seems the storage is soldered to the motherboard.
What if you unsoldered it?
That would require being very skilled at microsoldering. I mean, If you have the equipment and knowledge to do so go for it! But buying the equipment would really not be worth it. https://ifixit.org/blog/7321/know-about-...
buy another motherboard with a larger capacity chip. you can do a small upgrade depending if you have a 16 gb you can get a 32 gb hd also if you have 2gb memory you can get 4gb memory. look into it get the service guide . download.
I think you could as the Wireless chip is in the place an SSD would go. I am not 100% sure that you can, but you can try. Also, if you manage to do it, you risk your Internet.
No you cannot do that. The Wi-Fi adapter is using a type of PCI (probably PCIe Half-Mini) While the storage would use M.2 (either M.2 PCIe or M.2 SATA)
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 103
All Time: 6,192
