Presented at the April 2003 New York International Auto Show, for the 2004 US model year, the Prius was completely redesigned. It became a mid-size liftback, sized between the Corolla and the Camry, with redistributed mechanical and interior space significantly increasing rear-seat legroom and luggage room.
Headlight not getting power
Where is the headlight relay located?
Add a comment
1 Answer
@sirelrick your prius is a bit different than what we all maybe used to. "BEAN consists of body electrical systems such as body ECU, A/C control assembly, power source control ECU, combination meter, smart key ECU*, transmission control ECU, transponder key computer and gateway ECU. Gateway ECU has communication circuit to correspond with different types of communication data. Different types of communication data can be shared among communication parts after it goes through gateway ECU. Vehicle information is input to body ECU at an assembling plant as a representative ECU which delivers the information to other ECUs through multiplex communication.
  • Optional equipment
This system is working for the following systems:
  • Air Conditioning
  • Audio System
  • Brake Control System
  • Combination Meter
  • Cruise Control
  • Engine Control
  • EPS
  • Headlight
  • Hybrid Vehicle Immobilizer System
  • Illumination
  • Interior Light
  • Key Reminder
  • Luggage Compartment Door Opener
  • Mirror Heater
  • Multi–Display
  • Push Button Start System
  • Rear Window Defogger
  • Shift Control System
  • Smart Entry System
  • Taillight
  • TOYOTA Hybrid System
So there is no relay in the conventional sense. It uses a "Headlight Control ECU"
Add a comment
Add your answer
E. Bernardez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 676
