Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Touch Screen won't work after iPad screen replacement
Hey I just replaced both the LCD and touch digitizer on an iPad mini 2 WiFi, and the touch won’t work. The LCD screen and the home button works completely fine but the touch screen won’t to anything at all and is completely unresponsive.
Here are pictures of everything:
https://imgur.com/a/cTKXf
Add a comment
Most Helpful Answer
it looks like you have ripped a pin from the board connection, from the photo, bottom row near the centre
Score 1
Add a comment
Logan Davis like daniel already mentioned, you seem to have broken a pin. Well, actually it looks like you have broken a few.
Check the logic board connector and see if those are really broken. If so you will need the service of a microsolderer to repair this by replacing the connector.
Score 1
1 Comment:
That digi connector is really crap and breaks pretty regularly. It can be replaced by a micro-solderer.
by
Add a comment
Add your answer
Logan Davis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 97
