Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
Why does it keep logging out (has over 50% battery charge)
Hi all,
I recently changed the battery on my iphone 6s using the ifixit kit, followed the instructions. The only thing I didn't do was remove the screen entirely, had it propped up at 90 degree angle while I replaced the battery. I also found that the battery connector wasn't so flat, I pressed it down and screwed it in.
The first 2 days it was fine but today after a full charge it logs me out when I'm on it for a about 1min. Then I need to log in again either password or touch id and it goes to home screen not to what I was doing before. For example I'm on the internet then then loading wheel appears, goes black and then then the log in screen appears, then I'm back to homescreen.
Help? What might be wrong?
Add a comment
1 Answer
Loading screen means the phone is being told to turn off, probably due to the phone thinking the battery is too low (flat battery).
I would assume the replacement battery is faulty.
A recent iOS update also has caused issues with the phone soft-rebooting itself if the date and time was not set manually, this may or may not be related to your issue.
Add a comment
Add your answer
Sylvia will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 69
