Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone keep crashing without using any app
Hello there,
I got 3 x iPhone 6 with same issue of crashing iOS this morning.
It just goes to black screen with loading sign and comes back to ask Passcode. It is not App just happens without even opening any App. It is not battery or any other hardware as I did check. As per clients it happened over night in Auckland NewZealand.
It is quite strange issue because it didn't happen straight after update.
Any one has any idea? What it could be and possible solution?
Add a comment
Chosen Solution
Hello Ben,
The manual time thing didn't fix the issue but I found a solution, actually, it is due to notifications, So I just turned off notifications.
Settings > Notifications > Show Previews > Never
Source: https://www.theverge.com/2017/12/2/16727...
Phones are working normally. It worked for me...
Thanks
Regards
Danesh
Add a comment
Most Helpful Answer
The recent iOS update has a bug where if the system date and time is not set correctly the phone would keep rebooting every 5 minutes. Chances are apple will release a hotfix update for this in a few days.
The solution to this for the time being is to manually set the date and time and leave it manually set.
Score 1
Add a comment
Add your answer
Danesh will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 944
