The Chevrolet Cruze is a compact car made by the Chevrolet division of General Motors. The Cruze was first released in 2008 with a front-engine, front-wheel-drive layout.
32 Questions View all
Window stuck rolled down
My husband rolled down his drivers side window this morning and it will not roll back up. It's a 2015 so shouldn't be an issue yet, but unfortunately it is. He can hear the motor for the window, but the window is stuck down in the door. Any tips/tricks on how to get it to come back up without having it replaced or taken to a shop?
Score 1
6 Comments
I also have this problem on my 2014, and I just put a new regulator and moter. It rolled down but wont roll up again.
by
@raycruze Hi, Raymond. The Chevy Cruze is notorious for having the windows slip off the track. I just saw one with both the passenger and driver’s side windows off the track this last week. You’ll need to take the door panel off and most likely replace the regulator, although sometimes you can put the window back on the track without having to replace it. Look for the broken bits of plastic that hold it in place. Here’s a video of someone performing the repair you need. Good luck!
https://www.youtube.com/watch?v=wJQLo2do...
by
Tried to roll window down didn't realize it was frozen heard a loud pop can hear the motor running but window won't roll down. What can thank be. 2014 Chevy Cruze
by
You need a window regulator, if can hear motor wont need one with motor.
by
We just fixed / replaced the window regulator on our 2015 Chevy Cruz. Now it tells me that my door is opened, and says to roll/ open close my window, my doors won’t lock, radio won’t turn off when you open the door and when I roll the window down it’s extremely slow to roll up. What can I do or should I take it in?
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
Hi, Shea. The Chevy Cruze is notorious for having the windows slip off the track. I just saw one with both the passenger and driver’s side windows off the track this last week. You’ll need to take the door panel off and most likely replace the regulator, although sometimes you can put the window back on the track without having to replace it. Look for the broken bits of plastic that hold it in place. Here’s a video of someone performing the repair you need. Good luck!
Score 5
1 Comment:
I am trying to find a diagram on how the regulator works on a 2015 Chevy cruise. I have seen several videos on how to replace it but I want to see how one works when it is functioning normally
by
Add a comment
Add your answer
Shea Alyson will be eternally grateful.
Past 24 Hours: 28
Past 7 Days: 209
Past 30 Days: 1,118
All Time: 91,376
