Mini fridge cooling sensor cover broke off inside the freezer
The cooling sensor cover broke off. Can I still turn the freezer on in my GE mini fridge model wpr04bapbb?
@ptaliauli most likely you can. It is possible that this is just the cover. you do wan to make sure that you place the sensor back in the freezer part so that it will continue to read the temperature. It will help if you post some images of where this part is supposed to be located and off the damage. That way we can see what you see. Use this guide Adding images to an existing question for that.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 209
