Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
Is it possible to retrieve photos from a crushed LG6?
My phone was crushed and backup disabled. How can I get my photos out of the phone if the screen isn't working?
Score 2
Add a comment
1 Answer
Most Helpful Answer
IF USB debuggin mode was activated prior to the device damage, then you could side load an application onto it. however, this does not come stock, and it will not be turned on if you have had no reason to do so prior to this.
In that situation, you will need to temporarily put a good screen on, and run the transfer with a temporary screen. my store specifically, runs this procedure for $90CAD. You should be able to find a local shop to do this for you, or you can buy the screen, and try it yourself.
Score 1
Add a comment
Add your answer
Jonna DiStefano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 476
