Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327 Questions View all
Why do all video players stop moving
Whenever I watch something on the internet the video will stop but the audio will keep playing, the video will only start moving again when I move the mouse and I don't know why this is happening my computer is fairly new so it shouldn't be any processor problems
6 Comments
Does your screen go all black?
by
What is your OS Sierra or High Sierra?
by
no, the video just stops until I run my cursor over It
by
And your OS is???
by
The OS is Just Sierra
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
There is two possible issues here:
The first is the reliability of the connection to the source. This could be the server offering the stream all the way to your system via all the networks it crosses. The data stream breaks down enough the video part is unable to recover. If you back wind the vid to a section that was good it should recover.
The other possibility is the player is unable to buffer enough of the stream. This gets into how much RAM you have and available drive storage and if the connections data rate is very low it too can effect things. Ideally, you want to buffer in RAM, but if your lean on RAM as other apps are using it your drive will be used. If the data rate is low you may need to allow your system to buffer the vid before playing it.
Score 2
Add a comment
Add your answer
Batz Man will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 448
