The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
369 Questions View all
because my new 3ds xl does not turn on?
when dismantling my console new 3ds xl to change the rubber of the ABXY buttons and to mount it again it did not turn on anything or the blue focus. I notice little damage in the flex that connects the ABXY button board with the motherboard. Is that the problem that does not ignite anything?
1 Comment:
Hi!
Could you post a picture of the "damage"? Here's how to do that: Adding images to an existing question
Also, are you sure that you properly connected everything?
by
Add a comment
1 Answer
It sounds like you did not reconnect everything properly.
I have a New 3DS XL here that I'm working on and I've noticed that this one doesn't power up without the battery connected. I'm not sure if the old 3DS XL is the same way, but I'd make sure you have the battery connected when attempting to power it on.
4 Comments:
everything is perfectly well conetctado flex and vateria. I noticed that the flexing that connects the ABXY button plate to the motherboard has microscopic wear. My question is whether that flex has to do with the ignition ??
by
Well yeah, I mean the power button is located on that board.
I just realized that this was posted about the "3DS XL 2015" (not sure why iFixit doesn't just call it "New 3DS XL" like Nintendo does, but whatever) so I apologize for mistaking that in my answer above. With that in mind, do you have the battery connected when trying to power it on?
by
Hello there is no problem. the battery is connected when trying to turn on, my question is whether the flex that connects the two plates has to do with the ignition?
by
Yeah, as I previously commented, the power button is on the board that attaches to that flex cable. So if the flex cable is damaged then it's entirely possible that it could prevent power on.
by
Add a comment
Add your answer
Gamer pesolee will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 99
