No start or crank
Battery is good checked all the cables and fuses are good still nothing
First, turn on headlamps. If they're bright, and don't dim when the key is turned, the battery is o.k. listen for a click. if you hear any click, it's probably the starter. No click - try turning the key with the shifter in "N" Nothing - back to Park. At this point, it could be anything; ignition switch, neutral safety switch, open wiring, etc. If you want to pursue it yourself, you have to get a wiring diagram and test point to point. It can't be diagnosed on line.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 3,028
