Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Replaced screen, now home button is malfunctioning, but touch ID works
I dropped my phone and smashed my screen a few weeks ago. Everything worked fine (speakers, touch in all areas, screen colors were fine, flashlight, home button, touch ID, everything), just the glass was broken.
I replaced it using the guide on here, and everything works fine except for the home button. Touch ID works but:
  • Pressing the home button does nothing (feels the same, satisfying "click", but nothing happens)
  • Occasionally while using an app, it will exit to the home screen
  • While locked, the phone constantly wakes and sleeps
I've already reopened the phone and double-checked my work, re-seated the connections, inspected the connections and ribbon cables for any obvious signs of damage... but can't turn up what I might've done wrong.
Considering the button still worked with the old parts, I'm thinking of trying to get the home button ribbon cable that goes along the back side of that screen and trying it on the new one, in case I might've damaged that?
Add a comment
1 Answer
Chosen Solution
There is a chance that the long home button extension cable may have gotten damaged when removed from the old screen.
If you are planning to replace it make sure you buy the one with the metal plate together and not just the cable.
Score 1
2 Comments:
The screen I got actually came with the extension cable already in place, so I used the new one and did not attempt removing the old one from the broken screen. I am considering trying that though.
So currently, my phone is put together as:
* New display assembly
* New home button extension (pre-installed on the display assembly)
* Old home button (transferred from broken display assembly)
* Old guts
by
It is definitely worth a try using the old home button extension cable with metal plate. They can come faulty pre-installed.
by
Add a comment
Add your answer
bartmcarthur will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 56
