My Oxford advanced learners dictionary does not work
I have OXFORD ADVANCED LEARNERS DICTIONARY installed my operating system is MacOS High sierra 10.13.1.It stopped working from 15 11 17 onward.I understand that this O.S does not have Adobe flash drive & java.They also wanted to run a patch.After down loading I am unable to open.Please guide me.I am also enclosing the mail received from OXFORD ADVANCED LEARNERS DICTIONARY.Thank you
NARAYANAN LAKSHMANAN
- In replies all text above this line is added to the ticket ##
Ticket #24045: REFER OALD ,8th edition MAC: 17 NOVEMBER 2017 Sir, I have been using this OXFORD ADVANCED LEARNERS DICTIONARY since 2009 in my MacBook Pro. I recently purchased a new MacBook Pro 2017.The operating system is Mac OS High Sierra 10.13.1.It is not wo...
You can review the status of your request and add additional comments by following this link: https://oxfordeltdictionaries.zendesk.co...
Isabel T, Nov 17, 14:02 GMT:
Dear Customer,
Thank you for your email. I am sorry to hear that you have encountered a problem with your Oxford Advanced Learner's Dictionary, 8th edition CD-ROM.
With version 10.7 and later of OS X some additional steps are needed to run the OALD 8.
Depending on whether you have a clean install of OS X or not, you may need to install some additional components first.
With OS X 10.7 and onwards, Apple have chosen not to include Java or Adobe Flash, and these will both need installing if you wish to run the OALD.
If you try to run the OALD 8 without Java installed, you will see a pop-up window that will tell you that Java is required. You can download Java from: https://support.apple.com/kb/DL1572
If you do not already have Adobe Flash installed, you can download it from: https://get.adobe.com/flashplayer/
There is also a fix needed for the CD to work with newer versions of Flash. Please follow the steps below:
If you have not done so already, copy the files from the OALD 8 CD onto your Mac's hard disk, e.g. into the Applications folder.
Download https://d1o7bviwg2yey3.cloudfront.net/oa... and save to your Desktop.
Double-click on the file you downloaded to extract the contents - it contains two files, flashplayer.xpt and Flash Player.plugin
In Finder, right-click on oald8.app on your hard disk and select "Show Package Contents".
Navigate to the directory Contents/MacOs/plugins
Move the two files from archive "Oald8_FlashPlayer10_Patch.zip" to this plugins directory.
Delete the oald8 user preference directory ~/Library/Preferences/oald8 . Please note that '~' represents your home directory, and that this step may need performing for each user who has used the dictionary.
Restart OALD 8.
I hope that installing these extra components will solve the problem with your OALD 8. Please let us know if you need any more help with these instructions, or if you need any further help.
Best wishes,
ELT Dictionaries & Reference Grammar
Oxford University Press
www.oxfordlearnersdictionaries.com
Customer, Nov 17, 13:56 GMT:
Sir,
I have been using this OXFORD ADVANCED LEARNERS DICTIONARY since 2009 in my MacBook Pro. I recently purchased a new MacBook Pro 2017.The operating system is Mac OS High Sierra 10.13.1.It is not working from this morning but it works with C.D, I am unable to install it in the laptop and access it. I will be obliged to have latest patch to work the same.I will be obliged if you can consider my request.I am from INDIA.
Thank you
Best wishes
Yours sincerely
Lakshmanan.N
This email is a service from Oxford University Press, ELT Dictionaries and Reference Grammar.
Oxford University Press (UK) Disclaimer
This message is confidential. You should not copy it or disclose its contents to anyone. You may use and apply the information for the intended purpose only. OUP does not accept legal responsibility for the contents of this message. Any views or opinions presented are those of the author only and not of OUP. If this email has come to you in error, please delete it, along with any attachments. Please note that OUP may intercept incoming and outgoing email communications.
[ZQQMKW-O3VM].
