Repair guides and support for your Samsung TV.
2626 Questions View all
Black Screen no sound, standby light is on, remote blinking red
I'm having issues with my Samsung TV. Model UN60KU6300F. TV was on and was accidentally unplugged from the outlet. Once it got plugged back in, we lost the picture, just a black screen.
The backlights are on, no sound or anything. I get absolutely no picture. A few times when turning it on I've seen the Samsung Smart TV logo come on the screen for a second or two then disappear, then back to black screen. Of course the TV is conveniently 2 months out of warranty. Since I have power I'm deducing it wouldn't be a fuse. I have taken the back panel of the TV off and all the capacitors look flat, none are bulged. Any ideas on next steps?
3 Comments:
@hayeswg4 there should be a few fuses on the power board. check on those. For now it does appear as if you are having trouble with the main board since your backlight does come on. Post some good images of allof your boards and how they are assembled on the chassis with your question. Use this guide for that Adding images to an existing question It will allow us to see what you see.
by
Nothing connected to the TV. Even with it plugged into the wall by itself still has the same issue. I ordered a new main power board and T-Con board to replace them, hoping that fix does the trick.
by
did it work?
by
Add a comment
1 Answer
Hi... Do you have anything else connected to the tv that might need to be reset?
Add a comment
Add your answer
Wyatt Hayes will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,084
