The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
799 Questions View all
Tab inside charging port bent and won't accept charging cable.
There seems to be a small tab inside the charging port that slides into the slot in the charging cable. This tab appears to be bent from my child persistently attempting to plug the power cord in upside down and now the charging cable either won't plug in appropriately or make a good connection and charge.
Add a comment
1 Answer
Hi Kat,
Yes my kids do exactly the same, it sounds as if one of the pins inside the charging port is bent or broken off. This will require you taking the device apart and ordering the required charging port for your device. It will require you to remove the old charging port from the board and re-soldering a new one on to it.
Add a comment
Add your answer
Kat will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 8
All Time: 221
