My phone keeps beeping while trying to charge.
IF I turn it off and plug in to charge, it will stop making a beeping noise for a couple of minutes than turns the phone back on and starts beeping.
a couple possibilities.
1) the charge port is sending an interrupted signal. This is fixed by replacing the charge port.
2) The device has water damage. ive seen this happen frequently with water damage. it may need a corrosion clean out
3) corrupted software. Start with a hard reset, (Home and power for 20 seconds). if this doesnt fix it, try a factory restore. FACTORY RESET WILL ERASE ALL USER DATA.
4) Its weird, but i have had a couple instances where there was a short in the screen flex causing this issue. Replacing the screen fixed the issue.
5) Board failure. This is not repairable at a basic level. You would need to have access to schematics, and component types, as well as an expertise in SMT soldering.
^This.
It could also be
6)a bad/damaged cable.
7)cluttered charging port (this is easily fixed by using a ESD Brush and brushing the port.)
thank you for the input Juax, I will strive to be more detailed next time.
@vavallme The Interrupted signal being sent from the charging port, is caused by one of the two things Juax has posted.
I changed my lightning cord and the beeping stopped. iPhone 11
Bad charging cable .. causing intermittent connection issues. A new cable should fix the problem ..
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 30
All Time: 53,800
1 Comment
sdhould it show green in the corner
by cathynancy
