Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
iPhone 5s will not restore, stuck in recovery, getting error 9 code
Hello. I recently bought an iPhone 5s from a friend, it had a cracked screen and I had another 5s I received that is a parts phone. I replaced the screen using the ifixit tutorial and the device has been working just fine. Except for the touch ID scanner and I read that restoring the iPhone would possibly make it work. So I loaded up the latest version of iTunes, plugged the iPhone into my USB port using a genuine Apple charger and went to restore it. Now it is stuck in recovery, and when I go to restore it, I get an error 9 code after iTunes finishes "Extracting Software". I have nothing on this phone that I care about, I don't mind losing any info. I just want it to work. I don't even care if Touch ID works. Any help would be greatly appreciated.
Score 1
1 Comment
Have you tried to contact and ask Apple Technical Support directly? Maybe you should call or write to Apple team if you have such a difficulty? I've just run into this information https://apple.pissedconsumer.com/custome...
by
Add a comment
1 Answer
Chosen Solution
Download the firmware manually from http://www.iclarified.com/750/where-to-d....
Put the iPhone in DFU mode
Then use 3uTools to restore the firmware.
http://www.3u.com/
Score 4
6 Comments:
I am trying it out to see if I can get it to work, thank you for your advice. 3uTools is a nice program. It is also pretty simple to use. I will let you know the outcome when I finish.
by
After trying to flash it. I received a “-1” error code after reaching the 20% mark in 3uTools. After some research. It says that the error code is hardware related. I have an idea of what it may be and I’ll be trying it out. Thank you once again. I am going to accept the answer as it did indeed help me get closer towards my solution.
by
Error -1 on 3uTools may probably caused by baseband. But you can try to change the USB cable and try to restore again.
by
@soulxcx did you solve the problem? i have the same issue, error 9 in itunes and error -1 at 19-20% in 3utools in an iphone 4. Please help.
by
me too soryn_yly
by
Show 1 more comment
Add a comment
Add your answer
Ethan Cressman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 5,005
