Why is my screen shaking badly
My screen randomly starts flickering a lot and i have had this problem for almost a month. I can still use it but it makes it very hard. It happens on and off
Back up your device if you can, if not keep in mind that there is a chance that data may get lost.
I'm unsure what OS you are running, but if you have updated in the last few months make sure you are on the current OS (11.1). The OS from 11 to 11.0.1 and 11.0.2 have been known to cause random issues.
If that did not help, then it's most likely the screen. If you're able to open it just follow theinstructions carefully and be very mindful of the screws placement. While doing this, inspect the cables, look at the pins. Put everything back in order and see if it corrects the issue.
Hope this helps good luck!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 10,434
